BMW Fuel Filter Replacement Interval and Cost
3 years 11 months ago #707 by RadioFlyer
As a result of assisting that fellow from Colorado sort out his fuel pump issue I noted the following about BMW fuel filters in recent model bikes.
In the US warranty booklet there is a specified fuel filter replacement interval of 24,000 miles for all models. I could not locate a Canadian source that addressed the replacement interval.
In both the US and Canada the fuel filter is not available as a separate part from BMW but only as part of the entire fuel pump assembly.
For the R1220/1250GS bikes that assembly has a cost of $1060 (in the US it's $518).
In those bikes the fuel filter is a MAHLE KL 315 which can be purchased in the aftermarket for far less (note that there is a small o-ring on top that does not come with the filter). I know the F800 bikes use the same filter but I can't say about other models.
I find it very strange that BMW would recommend regular replacement of the fuel filter yet not sell it other than as part of an enture fuel pump, assembly.
The following user(s) said Thank You: danmaja
