- Thank you received: 0
2002 R1150RT Intermittent Power Failure
- Daniel
- New Member
8 years 1 month ago #200
by Daniel
2002 R1150RT Intermittent Power Failure was created by Daniel
With neither rhyme nor reason, every now and then my bike dies while Shifting Gears.
Hot or Cold; 1-2 or 5-6 and everywhere else in between.
At least once a week while cruising along my bike will just loose power and "Shut Off".
Depressing the Clutch and Pushing the Start Button brings her right back to life in an instant, but still...
It's a pretty weird experience (especially at highway speeds) that never fails to get my (immediate) attention.
Any idea's what might be happening? Anyone?
Tks,
Daniel
Tks,
Daniel
8 years 1 month ago #201
Replied by waynecorley on topic 2002 R1150RT Intermittent Power Failure
Hi Daniel:
I can't say I've heard of this one before. You mentioned it happens when you're shifting gears. Can you tell if it dies when you pull in the clutch or does it die when you toe the shifter? I know it happens pretty fast but the difference might be a clue as to the source of the problem.
It almost sounds as if the motronic unit is getting confused. Poor/dirty connectors? Poor grounds?
Not much help I realize. If I come up with any other ideas, I'll post them up. Good luck.
- Daniel
- New Member
8 years 1 month ago #202
by Daniel
Replied by Daniel on topic 2002 R1150RT Intermittent Power Failure
I'll pay close attention and let you know if I can find the exact event.
Thanks for your support anyway Wayne. It means a lot
- Daniel
- New Member
8 years 4 weeks ago #205
by Daniel
Seems to be that this problem is related to either the Side Kickstand Switch, or the Gearbox Gear Indicator Switch, or both?
Now all I need to do is find the Courage (?) to start pulling switches wires and other thing-a-maginers apart...
- danmirabent
- Junior Member
8 years 3 weeks ago #220
by danmirabent
Replied by danmirabent on topic 2002 R1150RT Intermittent Power Failure
Usually is the kickstand switch, you can remove it and bypass to make sure.
Cheers
Dan
Cheers
Dan
The following user(s) said Thank You: Daniel
- Daniel
- New Member
8 years 1 week ago #227
by Daniel
Thanks Dan. I'm pretty sure you're right...
