- Thank you received: 0
Are the any Technosynthese Alternatives?
- Daniel
- New Member
8 years 2 months ago #188
by Daniel
Are the any Technosynthese Alternatives? was created by Daniel
The previous owner (from 0-100K) of my 2002 R1150RT was using Motul 4T 5100 Technosynthese oil, and since taking it over I have been doing the same. However, while watching Chris Harris on You Tube to get a few pointers before scraping my knuckles again (I got blood all over the Fairing yesterday from my blood soaked wrists when changing the Pilot & Headlight Bulbs), he suggested NOT to use Synthetic Oil in this bike.
So far, he's been pretty much spot on with his advice, and so my question to you all is what type of alternative Non-Synthetic Oil do you (anyone?) use?
Thanks in advance for your help,
Daniel
Daniel
- danmirabent
- Junior Member
8 years 2 months ago #190
by danmirabent
Replied by danmirabent on topic Are the any Technosynthese Alternatives?
Hi Daniel, Motul has a mineral oil with the same weight as synthetic, however on my humble opinion (not as good as Chris Harris probably) there is nothing that synthetic will affect the R1150RT. With oils there is lots of myths and old wires tales, the most important thing now a days is just to make sure that whatever oil you use has 2 things, 1.That it is a motorcycle specific oil for 4 stroke 2. The right weights for your engine (viscosity).
The motorcycle specific oil has additives that help preserve the engine and more specific the wet clutch on the engine, using car oil (mineral or synthetic) even if its the right weight, will affect the performance of the clutch and can actually accelerate its wear, the only motorcycles that are inmune to this are the old dry clutch boxer engines.
Another myth is that if you have synthetic already on your engine and need to top it up you have to wait till you find synthetic (or vice-versa with mineral), this is a myth, as long as the weight is the same you can mix them, and if you don't find the right viscosity, the golden rule is: any oil is better than NO oil.
The main thing is always keep the scheduled oil changes and either mineral or synthetic that will keep your bike running for miles.
Cheers,
Dan
Cheers,
Dan
The following user(s) said Thank You: Daniel
8 years 2 months ago #191
Replied by waynecorley on topic Are the any Technosynthese Alternatives?
Hi Daniel:
Just curious, but did he give any specific reasons not to use synthetic in the RT?
I've been running synthetic in all my bikes for quite a few years with no ill effects that I'm aware of. My understanding is that synthetics can handle higher temperatures without breaking down. That's particularly important for air-cooled engines or even air/oil cooled engines like ours. Another benefit is you can go longer between oil changes and that's a plus if you're embarking on a long tour.
I agree with Dan that the most important thing is regular oil and filter changes. If you change Dino oil more frequently it can still be less costly than synthetic. By the way with our dry-clutch bikes, even the need for motorcycle specific oil is less relevant but I use motorcycle oil regardless.
- Daniel
- New Member
8 years 2 months ago #193
by Daniel
Replied by Daniel on topic Are the any Technosynthese Alternatives?
Great insights, Dan. Thanks so much for the advice
- Daniel
- New Member
8 years 2 months ago #194
by Daniel
No Wayne, he didn't mention why. However, as the bike was regularly serviced by S&R Island BMW I will assume that it was their suggestion. However, as the last 'Shop' Service entry was at 100,000 kms (2008) and I took the bike over at 112,000 kms (September 2017) I felt it best to do ALL fluids right away because between this period there are no records (I am the 3rd owner). At the start of this season I have completed an Engine Oil change, Gear Oil & Final Drive Oil, as well as 2 New Tires (April). This past week I replaced 2 Light Bulbs and yesterday (at 115,500 kms) the 2nd Engine Oil Change. I know that's only 3000 kms between Engine Oil changes, but I wasn't too sure of the condition so I decided to do it early to see what the situation was, and I'm glad that I did (except for having to pay $17 per Litre for the Motul Technosynthese) because at least now I know where I stand (it was pretty clean with no debris).
Further to your advice, and that of Dan above, I will continue to follow through with the Synthetic Product as it seems to work just fine for you; and that's good enough for me!
Do you have any suggestions on Brands that are less expensive than the Motul at $17 per litre?
Thanks again for all of your kind advice; it sure helps be breathe a little easier knowing that I'm on the right track.
Daniel
Daniel
8 years 2 months ago #195
Good plan to change all the fluids right away when it is an unknown. Have you flushed the brake fluid yet? Apparently that's pretty important with the ABS in our bikes. It was done on mine just prior to me buying it but that's a job I plan to tackle sometime this summer.
I've been using AMSOil 20/50 synthetic which I've been getting through Gary Smith, one of our members. I'm ordering some now so I'll let you know the current price when I find out. I think it was $15-16 per quart last time I bought some.
