Local Bearings Source?
4 years 2 months ago #508 by RadioFlyer
Is there a local source of name brand bearings (SKF, FAG....) that someone can recommend?
Thanks,
Mike
4 years 2 months ago #509 by tskucher
Replied by tskucher on topic Local Bearings Source?
I’ve had good luck with Applied Industrial Technologies on Campion Street, as well as Mearl’s Machine Works on Richter.
The following user(s) said Thank You: RadioFlyer
4 years 1 month ago #523 by brianbrowning
If you know your numbers, I've had good luck with Lordco. Believe it or not.
4 years 1 month ago #524 by RadioFlyer
Replied by RadioFlyer on topic Local Bearings Source?
Thank you. I will check it out.
4 years 1 month ago #576 by RadioFlyer
I went to Applied but they only sell to businesses. I was able to get the wheel bearings I needed over the counter at Mearls.
4 years 1 month ago #580 by tskucher
Good to hear that you found them at Mearl’s! That must be a relatively new thing at Applied because I’ve purchased bearings from them for personal use, though it has been a few years.
